Could not activate cellular data network
My internet on the phone is not working. I have 750 mb but I cant use it. It says "Could not activate cellular data network. You are not subscribed to a cellular data service." I dont understand that I have been using that phone all over the world with different international simcards and plans and never had any problem.
Photo of Pia
Pia
  • 80 Points 75 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
That's odd. Do you have the correct APN settings in the phone?
https://c.getsatisfaction.com/koodo/t...
Photo of Pia
Pia
I do and the internet is working with the WIFI without a problem but not with the 3G.
Photo of Jonathan I
Perhaps you have a data block on your account? That's really all I can think to be the issue. As long as the phone supports 3G frequencies 850/1900 the calls and data should be fine.
