cost of data?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 mentions
I have an old plan (no data included) and data is no longer an optional add-on so I wonder how much will I be charged if I use data ?
Photo of Heidi Weber
Heidi Weber
Photo of Boolanger
Boolanger
  • 9,234 Points 5k badge 2x thumb
It should still be the same data as when you signed up. You can check the data charges in self serve under Plan and addons→ Plans and if you hover over your current plan it should advise of the data costs
Photo of Dennis
Dennis, Mobile Master
  • 196,816 Points 100k badge 2x thumb
If you don't see it, call Koodo to ask.
*611 on your Koodo cell, it's a free call
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
What's the name of your plan? If I knew which plan you were on I could tell you what the usage rate is.
