Correct Textra MMS settings?
  • Updated 8 months ago
I am using Textra on my Galaxy S7 Edge and I'm wondering if I can get confirmation that my MMS settings are accurate. I recently received some photos and some of the attachments were automatically removed so I am thinking my settings are wrong. Within Textra under MMS settings I have the carrier send limit set to No Limit. I read somewhere that choosing No Limit could sometimes cause an issue with the carrier? Under MMS Behavior I have it set to system with the option to change it to Legacy. I'm not sure what this means, can someone explain this to me and if I should be using Legacy instead?
Photo of Slawek Bielawa
Slawek Bielawa
  • 150 Points 100 badge 2x thumb
  • confused
Posted 8 months ago
Photo of Robert
Robert, Mobile Master
  • 103,734 Points 100k badge 2x thumb
Slawek Bielawa
Yes I did see this thread but it is Verizon specific. I'm wondering what Koodo should be set to. 1mb, 2mb, no limit?
Photo of Dennis
Dennis, Mobile Master
Here are my settings on my s7 edge
Photo of Dennis
Sorry internal server error so it wont upload my image.
Mine is set to 1MB
Slawek Bielawa
With system or legacy?
Photo of Dennis
Legacy
Slawek Bielawa
Thanks, and you leave manually configure apn off?
Photo of Dennis
Correct
Slawek Bielawa
Thank you very much, I will give this a shot
Photo of Robert
Hello, was your problem solved?
Slawek Bielawa
Too early to tell. We shall see
You can test it by sending yourself and MMS message.
Slawek Bielawa
I was always receiving MMS messages.  My issue was when a bunch came in a row I got a message that some of the attachments were removed.
