Contact problem, Cellphone won't remember first 3 number.
My android cellphone crop the first 3 number of a contact so it won't get throught. If the person is not in my contact it works just fine. Would you know how to repair that problem? As an exemple if I text (XXX) XXX-XXXX for the first time it get throught but if i just click on it in the message box or on a contact it will text to XXX-XXXX instead.
Photo of Félix Boulet
Félix Boulet
  • 80 Points 75 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
It's probably a setting in your phone, Felix. You could try to program the number as +1 xxx xxx xxxx and that might solve your problem, or see if you entered a default area code somewhere.
What Android phone is it?
Félix Boulet
It is a JK-12 by Jiake, I tryed the +1 and that didn't work sadly. I did not find a default area code neither.
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
Isn't there a setting that says something about an area code being added to all your phone numbers? I never heard of this phone but you could look around on the Internet. It is the best advice I can give you
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Doba soft reset deleat everything restart new if don't work is your software os a hardware reset by holding power home at the same time that should work
