Connection problem's
I can not receive text, updates, and messages without wifi connection. Why is it only working with wifi?
Photo of brianna sookram
brianna sookram
  • 90 Points 75 badge 2x thumb
  • frustrated
Photo of Camilo_A
Camilo_A
  • 31,072 Points 20k badge 2x thumb
What kind of phone do you have?
Photo of Sophia
Sophia, Mobile Master
Hi Brianna,
There could be many, many possible causes for that, but we can get to the bottom of your issue :D
What phone do you have?
Do you have call access?
Do you have data set up on your phone?
brianna sookram
I have a Samgung galaxy ace
With the plan of just the unlimited texting
Photo of PD
PD
  • 6,798 Points 5k badge 2x thumb
Does this ever worked? Or worked with other phone?
Photo of Sophia
When you say "Just unlimited texting", do you mean the $15 prepaid plan or the $20 "regular" plan?
brianna sookram
15
Without a data booster this plan is unable to access the Internet without wifi. Also the phone has a known issue that it can not send text if wifi / data is enabled. You need to turn wifi / data off to text. It might be data to turn off. I can never remember.
If you want updates and Internet you need a data booster otherwise all you get is text
