connection problem.
Why does my iPhone continually lose connection to my home network wifi?
Photo of Brian Unsworth
Brian Unsworth
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
it could be because of your router connection range. This happens with me when there are alot of other people who are using it or when the router is starting to get hot and is trying to cool itself.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Also routers have a limit as to how many devices can connect to them at one time. It's possible you're at or close to your limit which is causing poorer reception for your devices (I ended up upgrading my router due to this).
Same here as far as replacing the router, also if your phone and router support it you should use the pushbutton setup method as it kind of 'pairs' the phone with your router.
