Comparing phones
can anyone tell me the difference between nexus 4 & 5?? thinking of upgrading not sure which to choose!! I have a Nexus S right now.
Photo of Angel Wylie
Angel Wylie
Photo of Dennis
Dennis, Mobile Master
  • 196,070 Points 100k badge 2x thumb
The Nexus 5 just came out recently and the Nexus 4 is a year old now.
If you decide on the Nexus 5, check out the Google Play store. $350 from Google or $500 from Koodo
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,270 Points 100k badge 2x thumb
If your the average user you won't notice a huge difference between the 2 other than the display on the Nexus 5 being larger and more crisp and vibrant. Also the battery is much better in the Nexus 5 which is good if you use your phone a fair bit.
The power user will notice a bunch of huge improvements in the Nexus 5 over the 4 though and it really comes down to how big a part of your life you phone plays.
If your looking at the Nexus 5 it is cheaper in the PlayStore like Dennis said but there's a month wait from the time you order so if you want it right away grab it from Koodo and pay the extra $100
Photo of Ivan
Ivan, Mobile Master
The battery life and the camera are just not good enough on the N4.
Photo of Jonathan I
Jonathan I, Mobile Master
Battery life wasn't terrible when I had the phone but I see where you're coming from, it wasn't exactly helpful. The camera was also pretty smudgy and suffered in low light.
Angel Wylie
Does the Nexus 5 have front and rear cameras.... some descriptions aren't clear or just plain doesn't say
Photo of Sophia
Sophia, Mobile Master
Yes, it does :)
Photo of Jonathan I
If you're going to get the Nexus 5, I definitely recommend getting it from Google. Sure it's unsubsidized, but you get both black and white color options, both storage options (16GB or 32GB), and it's a better outright price.
