Clear koodo emergency call from homescreen
How do I clear koodo emergency call on my phone? It is on my homescreen for some reason and I can`t use or access my phone.
Photo of Andrea Cowin-Hendry
Photo of Jonathan I
Jonathan I, Mobile Master
Wait, is it a message where you can't make calls or texts but you can navigate the phone or are you literally locked out of your phone? If the former, make sure you have 3G enabled in your settings (somewhere under mobile networks/cellular connections), airplane mode isn't on, then take out your SIM card, turn off your phone, and put it back together. If it's the latter, you activated some type of screen lock and don't know the password. You should be able to reset if you know your Gmail account details.
