charges without usage?
i do not use my mobile after 11pm but when i checked my data usage from past so many days it shows mid night 12:00am or 1:00am and so some data usage ? how can this be?
Photo of vijaya.s Nadakatti
vijaya.s Nadakatti
  • confused
Photo of B-Worrall
B-Worrall
  • 1,430 Points 1k badge 2x thumb
Unless you have your phone on airplane mode, it will usually be using a small amount of data for various apps you have. Many apps (I'd say the vast majority) will use small amounts of data in the background. You can also check, and limit which apps use mobile data though if you are worried about it. If the usage is only a few hundred KB then I wouldn't worry about it too much unless you have a minimal data plan.
