charges for unanswered calls incoming from Canada when abroad without add on
  • Updated 1 year ago
Hello, I am on a Canadian plan and am currently visiting Europe. I do not have an add on and was wondering: do I get charged for unanswered calls incoming from Canada? Thanks!
Photo of Michelle Ponert
Michelle Ponert
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
No, as long as you dont answer them you will not get charged. You also get free incoming texts. Just make sure your data is turned off and you can travel worry free!
If it goes to voicemail when you listen to it there would be a charge, 2 min I believe
Photo of Allan
  • 56,526 Points 50k badge 2x thumb
You woyld recieve charges for however long your call to your voicemail is, not necessarily just 2 minutes but that would be an outgoing call not an incoming like the OP was asking about.
