Charged for long distance help plese!!
They charged me 21 bucks for long distance and I think it was because I called a number but I did not know it wasn't toll free...
What shuld I do??
Will they take it off my bill if it was a mistake?
Photo of Dena Huynh
Dena Huynh
  • 200 Points 100 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
It's really up to the agent's discretion but if it was an honest mistake they should take good care of you.
Photo of Dena Huynh
Dena Huynh
I'll try to call them... I was calling a store because they messed up on my order and I thought the number was toll free....
Is there a big chance they will help me or small chance?
Photo of Dennis
Dennis, Mobile Master
  • 196,866 Points 100k badge 2x thumb
It's purely at the discretion of the agent. So no promises.
Just be polite, respectful, and honest. Yes it was a mistake, but you did honestly make the calls and you are charged correctly for them
Photo of Mayumi
Mayumi, Mobile Master
  • 115,204 Points 100k badge 2x thumb
"Toll free" still uses your anytime minutes.(if you don't have unlimited)
Photo of Dena Huynh
Dena Huynh
I didn't use the toll free number because I thought I was using it but turns out It wasnt.
