Charge problems after recent update?
  • Updated 8 months ago
  • (Edited)
2 weeks ago, My wife's and my  Galaxy5Neo were System Updated, we have experienced various problems since then, which I have already posted on.
 Last week Wed thru Friday her phone would not hold a charge going to 0% in an hour after recharging. Saturday early a.m. hers started working OK again and is still good today. However, today (noon) mine was charged to 100%, but was dead at 0% at 2 p.m,  (when I turned it on so a grand kid could play a game). Appears to be the same issue., but (research wise) it is early days for my unit. Both phones are 6 months old and have not had charging problems before.
 In the three days my wife had a problem it was consistent, 1 hr to lose charge and the typical 4 hrs to charge back to 100%. Then, repeating (just like deja vue all over again :) ) charge was back to 0 etc, etc.. Any ideas , comments would be appreciated.
Photo of stillgolfing
stillgolfing
  • 1,920 Points 1k badge 2x thumb
Posted 8 months ago
Photo of Goran
Goran, Mobile Master
  • 90,426 Points 50k badge 2x thumb
You can attempt a factory reset to see if it fixes it. If not you might need to use the warranty. That's a severe break of something.
Photo of Dinh
Dinh, Mobile Master
  • 32,722 Points 20k badge 2x thumb
You could go into Settings --> (Or general)--> battery and see what is draining your battery? There might be some cue to the bleed.
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
There is most likely an app or system resource "stuck" running and consuming your battery. Is your phone heating up? I would try a backup and then factory reset first.
stillgolfing
Thanks all! :) Will work my way thru ur suggestions.
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
OS updates tend to throw things out of whack with some devices. If you're referring to the Nougat update the S5 Neo received recently, by all means factory reset the device. (I did a factory reset right after the update). If you don't already have Samsung's Smart Switch software to backup the contents of your device, you can obtain the software from the link below.
See the heading on the right side of the page titled 'Get Samsung Smart Switch'
http://www.samsung.com/us/support/smart-switch-support/#!/
