Changing plan deletes my previous add-ons ??
  • Updated 2 years ago
If I change my plan I will still have the add-ons I had before. Like Int Long Distance Promo?
Photo of Addiel Isaac Moldes de Moya
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 103,908 Points 100k badge 2x thumb
Hello
You should be able to keep your add on. Never lost mine when I changed my plan
Thanks for your answer. Did you have the default ones or you added or removed some of them before changing the plan?
Photo of Robert
I only changed my plan didn't do anything with the add ons.
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
If your "add-ons" were part of the plan, then you will lose those ones.
Photo of Bernard
Bernard, Official Rep
  • 75,650 Points 50k badge 2x thumb
@ Addiel, the international promo is not a part of your plan, you can change plans no problem.
