Changing phone?
Hello,
If I want to change my phone and still use the same sim card, do I just put my old sim card in the new phone and then it works automatically with the Koodo network and my plan and all my contacts and all of that, or do I have to do something extra to get it to work?
Thanks.
Photo of anon
anon
  • 134 Points 100 badge 2x thumb
Posted 3 years ago
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey Ken!
As long as the current phone takes the same size SIMcard. You have to export contacts to SIM first, then import from SIM when the SIM is in the new phone. No you don't need to anything to make the SIM work in the other phone.
Photo of anon
anon
Hey, thanks for answering but I have a couple follow up questions. Does Koodo limit the number of devices you are allowed to have? Like for example, can a SIM card only be used on a certain number of phones a month/per lifetime and if so what is that number? Also, there's not any charge for changing phones half-way through a billing period or simply changing phones in general is there?
