Changing phone number and call forwarding
  • Updated 2 years ago
I recently moved from another province and need to change my number to a local phone number for job purposes. Am I able to set up call forwarding from my old number to my new number if I cancel the old number? I'm just wondering because I have already sent out job apps with the old number but I really need to switch now.
Photo of Beckei Sletten
Beckei Sletten
  • concerned
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,424 Points 100k badge 2x thumb
Unfortunately that is not possible.
Once you change your number your old number is gone.
I recommend getting another phone line and phone with a local number.  Something cheap and prepaid.   Then use that as a temp situation until you are ready to change your number officially
