Changing Number Through Self-Serve - Dropdown interface fails to display
  • Updated 2 years ago
I have an account with two phone numbers-- my partner's and my own. We moved out of province, so I am attempting to change my own number while he keeps his for now.
I am able to complete the first two steps-- I select a new areacode and a potential new phone number without difficulty. On step 3 I should be able to select one of the original phone numbers on my account to change from the dropdown menu-- but only a blank dropdown menu appears. Unable to choose anything, I tried clicking submit but the website comes up with a dialogue box prompting me to pick a number to change to move on. I have tried multiple browsers, a mac laptop and my android to see if the page loads differently but I've had no luck-- always the same empty dropdown box. All browsers are up to date. Seems like a interface issue. Anyone else encountered this?
Thanks!
Photo of BG
BG
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
What's your status on the account? Maybe you don't have the authorization to do such change because you are not the account owner?
Photo of BG
BG
Hi Robert,
I am actually the account holder.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
I would call Koodo *611 from your phone, option 6 for technical support.
Tell them you moved out of province and tried to change your phone number through self serve. But system doesn't allow you to pass the step 3. They will help you fix this :)
Photo of BG
BG
I'm going to do that now. Thanks Mayumi!
Photo of BG
BG
Hi guys: an update. You are unable to change a phone number through self-serve if you are moving province to province.
Thanks for your replies :)
Photo of Mayumi
  • 112,510 Points 100k badge 2x thumb
I remember it used to be unable to change a phone number through self serve if you moved to different province.
But I saw a few post that ppl could change through self serve even if it change the province.  Maybe they fixed it.
Thank you for update :)
