changing my phone and want to keep my actual plan
if i change my cellphone for an samsung galaxy s3 on the small plan and im actually on a small plan with a samsung galaxy ace 2x, can i keep my actual plan?
Photo of tikode357
tikode357
  • 290 Points 250 badge 2x thumb
Posted 3 years ago
Yes, I assuming by small plan you mean small tab.
You only have to change your plan if you upgrade your tab level from small and your current plan is less than 30$ (or you're moving to tab large)
Otherwise you can continue using tab small and keep your plan.
Photo of tikode357
tikode357
okay, well I have a 59$ plan on a small tab and i want to change my phone but i'll stay on a small tab but can I keep my plan?
Yes
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
You could also switch to a Tab M and keep your plan. Even though there is a $5 monthly Tab M charge it saves you money over 2 years
Photo of tikode357
tikode357
ok
