Changing base plan with auto top-up
  • Updated 8 months ago
I am currently on $55 1GB prepaid base plan (with auto top-up), and just saw Koodo is doing $55 2GB data promotional base plan.
If I want to switch to that 2GB base plan, do I need to do it before the next auto top-up? Or after the top-up, can I still switch to the new plan before the original one kicks in?
Photo of Stephen
Stephen
  • 152 Points 100 badge 2x thumb
Posted 8 months ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Stephen,
You should upgrade your plan near the end of it because you will be charged for it immediately. You might need to manually add the required ammount to your account in order to upgrade it.
Photo of Sophia
Sophia, Mobile Master
As long as you don't disable auto top up, you will get the 10% discount :)
If you want you can even lower the amount for one or two months to "even out", you'll still get the 10% over the entire base plan - not just the top up amount.
Photo of Stephen
Stephen
Thanks Mathieu and Sophia for the reply! I will change the base plan tomorrow then, getting that 1 extra GB for free is really a good deal.
Photo of Sophia
Actually Mathieu does have a point here (he always does, haha)... I'm not entirely sure if THIS ONCE you'll receive the 10% discount, because you will be going for a new plan. I have never changed base plans so... I might have given you a wrong impression. I'll keep my fingers crossed that you'll receive the 10% :)
Photo of Stephen
Stephen
I changed my base plan yesterday and still got that 10% discount. Thank everyone for help.
Photo of Sophia
Great! Now we know for sure!
