Changed from talk and text plan to data plan and the data hasn't kicked in yet
Last night I changed from talk and text plan to a data plan and and it's been 12 or so hours and my plan hasn't changed to data yet. Is it just because it's the weekend that it hasn't changed or something else?
Photo of mikayla
mikayla
  • 80 Points 75 badge 2x thumb
  • angry
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,046 Points 100k badge 2x thumb
Even with your talk and text plan you should still be able to use data.
After a plan change It should come into effect right away.
Make sure your data is enabled on the phone.
Also log into your self serve from a browser and you can check your plan to make sure it's a data plan.
Then go to Add-Ons and make sure Data Block is removed
Photo of mikayla
mikayla
I got rid of the data block and my data still isn't working is there anything I can do to fix it?
Photo of Dennis
  • 195,382 Points 100k badge 2x thumb
Try restarting your phone
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,270 Points 100k badge 2x thumb
Make sure your APN settings are set to those of Koodo's in the settings menu.
Here's Koodo's APN settings below.
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data. The frequencies are compatible so it should work.
