Changed data plan
  • 2
I have changed my plan to 500mb. I want to check to see if i did it correctly. Is the change immediate or does it take a couple of days
Photo of Brenda Patterson
Brenda Patterson
Posted 3 years ago
  • 2
It's an instant change.
When you log into self serve you should see your new plan in place.
Brenda Patterson
the old plan is still there
Photo of Sophia
Sophia, Mobile Master
Try to change your plan again, Brenda, I guess it didn't go through then :)
Brenda Patterson
I did it again and now its fine. I hit the wrong button.
