Cellular Data Problem!
My phone is a telus iphone but I'm using it with a koodo SIM card. Anyway, in cellular->use cellular data for, it only shows FaceTime and Passbook. It is supposed to show all my apps! Now I'm using so much data! What can I do?
Photo of Ify Morah
Ify Morah
  • 190 Points 100 badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
Have you updated the carrier settings through iTunes?
Photo of Ify Morah
Ify Morah
How do you do that?
Photo of Myke
Myke
Plug your iPhone into a computer with the latest version of iTunes. You should get a pop up notifying you about updating carrier settings. Click the confirmation button and it will update the phone with the proper settings.
Photo of Ify Morah
Ify Morah
Yeah, I don't have an update.
Photo of Myke
Myke
Contact Apple then. There's very little Koodo can do about this.
Photo of Myke
Myke
Maybe those are the only 2 apps that have used mobile data.
Photo of Ify Morah
Ify Morah
No. It's using data from my apps like instagram, mail, iTunes Store, etc.
