Cell not charging properly, help.
My Samsung Galaxy 3 s has trouble charging, sometimes it does and sometimes it doesn't. Phone was at 100 percent last night then 3percent this morning.
Photo of Peter Korotkov
Peter Korotkov
Photo of Curtules
  • 19,666 Points 10k badge 2x thumb
There are a few things that could cause charging problems. Damaged ports, defective battery, defective charger/USB cable. A few tests may be required to check what's actually going on.
But have you tried turning off the LTE? LTE connection can cause major battery drainage. Also, in the settings of your phone there is a battery option, you can use that to check whats draining the battery overnight.
Photo of Ivan
Ivan, Mobile Master
  • 95,468 Points 50k badge 2x thumb
First, try a different charger. When using a USB wall adaptor, make sure you use one that meets your device specifications (you may damage your battery otherwise).
Or, you can use a computer USB port for charging (takes longer but is easier on battery). In any case a computer port is capable of charging your device overnight.
And finally, unless you have an active GPS navigation app running, there's nothing that should be discharging your phone while it's plugged in at night. At worst, there should be zero charge lost, even with other apps running.
