CDMA phone for Northern Manitoba
Hi Koodo,
I am currently living in Snow Lake, Manitoba. We only have CDMA of MTS here. Do you guys have any phone would work for the region? I can't find it on your website. Can I use Motorola milestone from Verizon and activate it with Koodo? Will that work in Snow Lake, MB? Thanks
Photo of Thảo Đặng
Thảo Đặng
  • 162 Points 100 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
No the Motorola Milestone won't work on Koodo. Koodo only has CDMA coverage in Snow Lake Manitoba so the only phone that will work from Koodo is BlackBerry Curve 9320 https://shop.koodomobile.com/koodo-ce...
Since the CDMA network is all that's available for you that's your only option with koodo
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,242 Points 100k badge 2x thumb
I think you mean the 8530, the 9320 is an HSPA phone.
Photo of Thảo Đặng
Thảo Đặng
I got the motorola milestone off verizon. I know it is cdma for sure. My question would be if it can be programmed with koodo and how?
Photo of Daniel Kim
Daniel Kim, Mobile Master
cdma devices only work with their original carriers and cannot be unlocked so it will not work with koodo. :(
You are correct Timo the 8530 my bad
Photo of Chris Petersens
Chris Petersens
eBay is probably your best bet, but you can pick up some pretty good deals on some Koodo CDMA phones.
http://www.ebay.ca/sch/i.html?_trksid...
Photo of Thảo Đặng
Thảo Đặng
I dont know the phone type to search. It keeps giving me hspa phones :(
