Carrier settings update of iPhone 6s and LTE/3G/2G toggle
  • Updated 2 years ago
Hi everyone! I got a carrier setting update last Thursday. I clicked to complete it. Later I found LTE/3G/2G toggle was replaced by Enable LTE. Did you guys have similar experience? Is there any way to recover the toggle? Or could it be possible to recovery the toggle with future iOS updates? Thank you!
Photo of Papaxiong Boots
Papaxiong Boots
  • 844 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,976 Points 10k badge 2x thumb
It does the same thing basically.
Turned off, you will be on 3G.
Turned on, you will be on LTE
Koodo doesn't dictate the content of future OS updates.
I imagine the only way to get it back is to downgrade to an older version of the operating system.
(not recommended)
Papaxiong Boots
LOL. Thanks. Already tried. Not successful.
Mitchell Palmater
Then you're likely out of luck.
If you wanted that kind of control and customization you should not have gone apple hehehe
Papaxiong Boots
I changed chatr SIM card for a trial. The toggle is still there. I guess it may be related with different operators.
