cant recieve bbm or emails unless i am using wifi
  • Doesn't Need an Answer
i have a blackberry curve and can only recieve my emails or bbms when i am using wifi. What can i do so i dont have to reset my phone everytime i leave my house?
Photo of Leanne Williams
Leanne Williams
  • 80 Points 75 badge 2x thumb
  • frustrated
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
Do you have a blackberry specific plan? Is this a Koodo phone? Have you tried logging into https://koodomobile.blackberry.com/ and resending service books? Do you have network data disabled?
Tell us a little more details if you can....
Leanne Williams
This is a koodo phone and a i have a data plan. We checked the network data and was on.
Photo of mattjs
mattjs
Try going to https://koodomobile.blackberry.com/ and on the right menu at the bottom is an option to resend service books.
In options > advanced options > TCPIP > are APN settings enabled? What's showing there?
Also, you can try doing Options > Device > Advanced System Settings > Host Routing Table > Click your blackberry key > Register now.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Leanne, you should also make sure that you have the BlackBerry version of your plan. You can check via Self Serve and it indicate BB next to the plan's name. If there is none, that would explain why it doesn't work.
________________________
