Can't send picture messages from my S4, even with data enabled and on a data plan.
  • Updated 9 months ago
I recently (April 2015) bought a Samsung Galaxy S4 on a Koodo plan and I haven't been able to send text messages with picture attachments.  I am on a data plan and have data enabled but it just shows the little 'loading' circle animation under the text message for an indefinite amount of time when I try to send it.
Any ideas?
Photo of Jim Legs
Jim Legs
  • 80 Points 75 badge 2x thumb
  • Frustrated
Posted 3 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Check the APN settings and make sure they are correct:
http://help.koodomobile.com/plans-add-ons-data-and-other-services/data/how-do-i-setup-data-on-my-non...
Are you able to access websites using your data connection? Please make sure you are actually using your cellular network and not Wi-Fi. Also, did you maybe have a data block added to your account? You can check that in self-serve under the add-on tab
Photo of Sarah Jane
Sarah Jane
  • 270 Points 250 badge 2x thumb
Are you able to send regular texts ? I was having issues sending texts yestetday and same today. It seemed to work when I left my house but when I'm back I still can't send or receive anything. If it's towers than koodo needs to get their ass in gear as this is quite annoying.
Photo of sandra mackinnon
sandra mackinnon
  • 180 Points 100 badge 2x thumb
I have the same problem.  I can not receive picture text even with my data on.  HELP
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
In your mobile network settings, try changing network type to WCDMA/GSM without the LTE then restart the phone.
Photo of Jan Hope
Jan Hope
  • 4,356 Points 4k badge 2x thumb
Hi Sandra is you phone Galaxy s4, as well?
