Can't receive incoming calls
I just transferred my number from bell to koodo. I have an unlocked Blackberry Q10. I have been receiving texts and can make outgoing calls but have not been able to receive any incoming calls. I have a prepaid account which I topped up with phone minutes.
Photo of Yvonne MacMillan
Yvonne MacMillan
Posted 3 years ago
Did you add a talk booster to your baseplan?
Yvonne MacMillan
Yes I did.
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,976 Points 10k badge 2x thumb
How long ago did you set it up?
Sometimes during a number port you will only be able to make outgoing calls until the port is complete.
You will get a text from Koodo when the port is completed. (Sometimes takes up to an hour)
Meanwhile incoming calls will go to your old sim card.
Have you turned the bb off and removed \ reinstalled the battery. Also you say you just ported, has it been more than 24 hrs? Did you get a text saying the port. Had completed?
Yvonne MacMillan
Has only been a couple of hours. Will wait for the text.
Yvonne MacMillan
Ok thanks - just received the text and am up and running. Thx. For your help!
