Can't connect to swisscom network. What is required
  • Updated 2 years ago
I'm in Europe and I can't connect to the European networks. What do I need to have to do that
Photo of Judith Mueller
Judith Mueller
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 103,888 Points 100k badge 2x thumb
Hello Judith,
Have you added the free international roaming package from self serve?
Judith Mueller
Yes it's on
Judith Mueller
It says it can't connect
Judith Mueller
It says my simple card does not support a connection
Judith Mueller
Sim card lol
Photo of Goran
Goran, Mobile Master
  • 91,264 Points 50k badge 2x thumb
You need to have pay per use international long distance and international voice roaming on to connect roaming. If you want data, you will also need international data roaming on. You can do this in self-serve. You can also do the same for roaming packages. Once that's done your phone should connect to a roaming partner, although I'd personally suggest having your phone unlocked and using a local sim, such as from Lycamobile.
Judith Mueller
Thankd
Photo of Goran
So you're saying the roaming add-ons have been turned on. Ok now try going into manual network selection, wait 1-2 minutes for the list to populate, and se eif you can connect like that. Also, what phone do you have?
Judith Mueller
Samsung s7..I don't require data so I didn't turn that on
Photo of Robert
Here's how to add the free international roaming packages. There's two of them :
Connect to sell serve and go to your add-ons
Click to change the add-ons
Search for 1) International Voice Roaming and 2) International Data Roaming
Judith Mueller
I don't require roaming just want to be able to call if I have to
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
You have to have them for anything to work. The two add ons are free
Judith Mueller
Thanks
