Cannot find koodo network for weeks! Help!
samsung galaxy s says no network available. When I search for a network koodo doesn't even show up.. I have never had a problem with this up until 2 weeks ago. I cannot make a phone call even though I have all 4 bars! says emergency calls only.. How do I fix this? it there something wrong with the towers? so I need a new sim? Ive tried everything.
Photo of Sean Anne O'Keefe
Sean Anne O'Keefe
  • 170 Points 100 badge 2x thumb
  • sad and frustrated
Photo of Ivan
Ivan, Mobile Master
In your network settings, make sure that your phone isn't set to 2G only.
Try settings... Wireless and networks... More... Mobile network
Make sure you didn't accidentally enabel Use 2G only or Use GSM networks only
Sean Anne O'Keefe
When I go settings - mobile network settings these are my options.. 1. use packet data (that is turned off) 2. data roaming (that is also turned off) 3. access Point names 4. Network operators. There's no option for me to use 2g or gsm networks only
Thats Strange, Is Airplane Mode turned on?
is this an S4?
Sean Anne O'Keefe
No it is not on airplane mode. And no it is the S1
Can you find anything that say NETWORK MODE?
It should pop up this window. Choose the first option
Sean Anne O'Keefe
That pop up window doesn't come up. I restarted my phone and went into my mobile network settings waiting to see if it will pop up and nothing.
so there is no NETWORK MODE setting?
When you scan for networks, What does show up?
Sean Anne O'Keefe
Nope. No network mode setting. when I can for networks I get AT&T T-Mobile CAN rogers wireless inc. and 302610 (whatever that is). It also shows me koodo which is good but thats the thing! I will choose koodo and I will be connected for maybe ten mins then nothing.. so I scan again and I get all of the ones listed but no koodo
Sean Anne O'Keefe
Yup.. just went out again no more connection with koodo.
Sean Anne O'Keefe
I live almost right on the water front here in windsor across from detroit but I have never had a network problem
yeah that was going to be my next question. I frequently travel through there and very recently I get T-Mobile service in Windsor. there is a TON of construction going on around that area and it's possible a Tower had to be shut down or moved to accomodate all that action. I recommend you contact Koodo and have them submit a support ticket.
Sean Anne O'Keefe
95% of the time there is no koodo when I scan
You may actually benefit from a newer Sim card (Not to mention a newer phone) which may help you find other towers. For now it just seems like the USA signals are much stronger and thats why you're not finding Koodo. Any new phone you grab would come with a 15 day Money Back Guarantee so you could try it out and see if a new device would work for you. (You should check selfserve as you may be eligible for an upgrade with very little to nothing out of pocket)
Photo of KaneSlavik
KaneSlavik
  • 6,464 Points 5k badge 2x thumb
I wonder if the phone just isn't being accepted on Koodo's network.
why wouldn't it be? and why would she then get Koodo for 10 minutes?
Photo of KaneSlavik
KaneSlavik
Hypothetically speaking, the network could be delayed in realizing the device doesn't match the radio frequency then booting it off. I can't think of any other reason why the connection wouldn't stay.
weak signal, which would explain why when she rescans, it's not there.
Photo of KaneSlavik
KaneSlavik
Has it been stated what city this person lives in?
Windsor ON, Right next to the border -=- Keeps getting AT&T, TMobile, and CAN Rogers + 302610 (Bell)
Have you tried selecting the 302610 network???
Sean Anne O'Keefe
Thanks for all your help. I called tech support and they pretty much dont know wtf is going on lol. They checked it out and said AT&T has a higher signal. So Im gunna have to try out a new phone and return it if it doesn't work. And if that is the case then I need to switch companies.
What I don't understand is I have never had a problem with this phone and I have always lived this close to the boarder.
Photo of KaneSlavik
KaneSlavik
Have Tech Support log a ticket for the issue for further investigation.
yes but still there IS a MAJOR construction project going on there.
Your Landscape is changing dramatically.
http://www.hgparkway.ca/
In any event, I hope the new phone / SIM is not only AWESOME but that your issue gets resolved. PLEASE LET US KNOW!!!!!! Had fun trying to help.
Sean Anne O'Keefe
Yes and also right across the street from me they are building a new Military training base.. on that water.. my luck right?
Who knows, Maybe you discovered a malfunctioning Tower. :) Good luck Sean Anne
Sean Anne O'Keefe
I'll need it.. thank you lol
