Canada-wide $39 Talk, Text, and Data Plan ends May 1st!
  • Praise
We had a topic inquiring about this plan on Fido/Virgin and surprisingly the plan is not on the website but it is in Self Serve! So I took the liberty of scanning in the skinny page my rep gave me so everyone is aware. Grab it before it's gone, folks!
Photo of Jonathan I
Jonathan I, Mobile Master
Photo of PZABOY
  • 5,142 Points 5k badge 2x thumb
Wow! Thanks for taking the time and effort to share this :)
Photo of Tomislav
  • 798 Points 500 badge 2x thumb
Yep! I recently switched to it!
Photo of Erwin
  • 23,436 Points 20k badge 2x thumb
This plan looks amazing, the only thing about it though is that if you go over your 400mb data limit it is $5/200mb. While the $45 Canada wide Data plan, gives you same minutes, 500mb data, unlimited 5pm to 8am, plus if you go over your data it is $5/500mb.
But if you dont use your phone that much then the $39 is a perfect match.
Hope it helps.
