can someone help me?
my plan says i can use 2GB...but i'm only getting to use 1GB...the website says to self serve to change my account but i can not find thia option. any help?
Photo of Dallas Sinopole
Dallas Sinopole
Photo of Mayumi
Mayumi, Mobile Master
  • 111,102 Points 100k badge 2x thumb
Have you registered on Self Serve yet?
If not, here is the link to “How do I register for Self Serve?”
You can check your billing cycle, tab balance, account’s balance and the due date, etc. :)
When you create your Self Service account, the system sent you an e-mail to validate your e-mail to complete/activate the registration. So check your e-mail and confirm it then try to login again.
Photo of Dennis
Dennis, Mobile Master
  • 177,792 Points 100k badge 2x thumb
You can also check your plan and change you plans too.
Not sure what you mean by you are only getting to use 1GB
