can someone help
i got the $25.00 package i get Unlimited Messaging (Text and Picture) and Unlimited Local 7pm Evenings & Weekends,, but it wont let me send or receive picture? how can i do so ?
Photo of Deserry Mariee Wheeler
Photo of Dennis
Dennis, Mobile Master
  • 187,616 Points 100k badge 2x thumb
Make sure data needs to be enabled to send and receive picture messages.
Be careful of data leakage from apps that may want to use data to update in the background. Even though data used for picture messaging is free, any coincidental data used by apps in the background will count against you as regular data used
oh .. :/
Photo of Dennis
If you are worried you can make sure you are on a strong wifi connection and flip your data on to send/receive any picture messages then turn your data back off. This way any background data being used will go through wifi
