Can not activate my Nexus 4 on Self Serve....HELP please
I have a blackberry curve, a while ago i bought a nexus 4 and activated it...recently i had to go back to the blackberry, my question is how do i activate my nexus again on the self serve.
Photo of Stacey Oksanen
Stacey Oksanen
Photo of Myke
Myke
If you're using the same sim card, then you just put the sim card into the phone that you want to use. If you have a different sim card, then you would do a sim card swap on your Self Serve account.
Stacey Oksanen
its the 8530 curve,,, has no sim card
Photo of Myke
Myke
You still need to add your sim card to your account, which can be done through Self Serve.
