can I use the Koodo base plan with a phone that's not from Koodo?
Photo of Debbie Rice
Debbie Rice
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
If your phone is unlocked and compatible with the Koodo network, yes.
Also if you want to use your phone for the prepaid, you will need a phone that uses a sim card.
http://help.koodomobile.com/getting-s...
Photo of magitha have
magitha have
  • 90 Points 75 badge 2x thumb
Yes,You can do it.
But your phone should be unlocked one.
if it's network locked means,you will need to unlock it.
For unlocking you can approach your current network service provider or else try to buy an unlocking service provider like http://www.mobileunlocksolutions.com/... I hope it will be very useful to you.
Photo of Ivan
Ivan, Mobile Master
If the phone in question happens to come from Telus and is an iPhone (3GS and newer) or a Windows 7/8 or a BlackBerry 10 phone, then you will not need to have it unlocked.
