Can I switch to Iphone without my plan chaning?
Right now I have a Samsung and my plan is 45 a month. I want to switch to Iphone but I dont want my plan to be more expensive, will it?
Photo of Jennifer Demjen
Jennifer Demjen
  • 90 Points 75 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
Certainly, Jennifer! You will need to pay off your current Tab before you can get a new one, but you don't have to change your plan :)
Photo of Jonathan I
Jonathan I, Mobile Master
You can take either Tab S (up to 150 off a phone) or Tab M (up to - 300 off a phone, $5 Tab charge each month for 24 months) without changing your plan. Tab L will require a plan change.
Jennifer Demjen
Perfect thank you! I will probably do Medium because that sounds reasonable and my Tab is currently paid off ! I would normally stick with a newer Samsung but with Medium tab Iphone 5 is cheaper !
Photo of Jonathan I
You could also consider the HTC One (M8). Yes it carries the same premium price as the GS5, but in my opinion, is a superior device to both the 5S and GS 5.
Jennifer Demjen
I would if the camera was as good !
