Can I block phone numbers on my Koodo cell phone and how? What about for texts?
  • 2
Photo of Cierra Fehr
Cierra Fehr
  • 2
What phone do you Have?
Are you looking to block those numbers from calling you or block your phone from calling them?
Cierra Fehr
Nexus 4 with Koodo
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
Looking at the Nexus 4 settings, I could not see a way to block numbers. Blocking texting would not be available in the phone settings. I would recommend to download an app called Mr. Number. I used on on my last android phone and currently on my Nexus 4. Works pretty well for blocking calls and texts.
https://play.google.com/store/apps/de...
Photo of Larry
Larry
  • 80 Points 75 badge 2x thumb
Indicates my setting wont allow on my Nexus 4.I can not remove the all check mark in settings but all the rest are unchecked . Help
Cierra Fehr
That's excellent information - thanks for your help!
