Can I add a Koodo data flex plan to my account using Self Serve?
I wanted to upgrade my data plan, as I was going over each month. I deleted my old data flex plan and now I can't figure out how to add one back.
Photo of kяιstιnε cowie
kяιstιnε cowie
  • frustrated
Photo of Ivan
Ivan, Mobile Master
All plans have either a certain data allowance + flex type overages (you're billed for chunks of data rather than per MB, prices vary by plans), or pay-per-use billing (still for chunks of data - $5/mo. for 25 MB, $10/100 MB, etc.). You can find exact data allowances and rates here: https://shop.koodomobile.com/plans/pl...
There re currently no special add-ons for data. If you're using too much with your current plan, you should consider a more expensive plan that has more data. It may be cheaper than what you're paying now with overages.
Photo of Dennis
Dennis, Mobile Master
  • 196,910 Points 100k badge 2x thumb
Hi kяιstιnε,
Unfortunately this add-on is no long offered by Koodo as the new plans include the Pay-Per-Use Data Saver.
You can check out the new plans here:
