How do I check my past incoming and outgoing calls?
  • (Edited)
Photo of MrSmurf459 .
MrSmurf459 .
Photo of John Lee
John Lee
You can check your previous incoming and outgoing calls on Koodo Self Serve by clicking the Billing option, then your e-bill and then there should be another option that says "Previous Usage" and you can click the airtime usage and see your past incoming and outgoing calls.
