CAN NOT CONNECT TO RECENTLY PURCHASED PLAN
  • Updated 2 years ago
I am a new plan user. I am turning off WIFI on my android and turning on mobile data but I can not get connection! What am I doing wrong?
Photo of Guy Lefebvre
Guy Lefebvre
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Sophia
Sophia, Mobile Master
Is it just data you cannot get? Make sure you have entered the APN settings correctly if you did not purchase the phone from Koodo: http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
After that reboot the phone and data should work!
Guy Lefebvre
I think I did the APN settings correctly, all questions were answered as per the example. I have connection if I have WIFI on only, if I have mobile data on and WIFI off, I get a YOUR ARE OFFLINE message. Data roaming does not have to be on, correct? Other questions on the APN settings are "BEARER" saying unspecified, "MOBILE VIRTUAL NETWORK OPERATOR TYPE" saying GID, "APN PROTOCOL" saying IPv4. Also under network mode it says LTE/WCDMA/GSM (auto connect). And yes I did purchase the phone from Koodoo
I was just having the same problem and rebooting my phone solved it.
