Can I keep my plan when upgrade my phone
  • Updated 3 months ago
Photo of Rose Alonzo
Rose Alonzo
  • 72 Points
Posted 3 months ago
Photo of Allan
Allan, Mobile Master
  • 62,896 Points 50k badge 2x thumb
Official Response
Depends on how you are upgrading. If you buy your phone outright then yes. If you get your phone on a tab then it has to meet the requirements as shown in this link:
https://www.koodomobile.com/help/keep...
If you go through the checkout process, it will give you a prompt to change plans if its necessary. If it doesnt give you the prompt, then you're all good.
