can i have 2 simm cards with my same info on?
  • Updated 2 years ago
same micro simm card
Photo of rjb
rjb
  • 160 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 97,236 Points 50k badge 2x thumb
Simple and short answer: basically no.
More details:The old/second sim would only be active for 90 days from time of transfer to the new/first one, so it's possible for a short time period only. Do you need to be able to talk on multiple devices? There are call forwarding options.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,312 Points 100k badge 2x thumb
Just to add but only one of those SIM can actually be active at a time during that 90 day period and one would have to switch back and forth over self serve activating one or the other. You can activate each one every 89 or shorter days and that 90 days will begin again on the SIM not being used.
Photo of Sophia
Sophia, Mobile Master
True :) Except that when you activate the new SIM, the old one will not be active any longer (but you can revive it within 90 days, I guess that is what you meant) :) At no point in time will 2 SIM cards be active simultaneously.
Edit: cross posted with Paul
