Can I check my voicemail when roaming internationally?
  • Updated 2 years ago
International roaming with text only plan. Someone left me a voicemail and I'm not sure if I should listen to it. Thx!
Photo of k
k
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
I believe you would pay pay-per-use rates if calling to your voicemail. If you have Skype or other calling App on your phone, you should be able to call your number when connected to Wi-fi, and retrieve your message at a lower cost. Simply press * once your voicemail picks up, and then enter your PIN.
Photo of k
k
Thanks! Worked. I used Google phone, dialed my number and pressed * . Thanks again!
Photo of David
  • 91,518 Points 50k badge 2x thumb
Happy to learn it went so smoothly!
