Can I bring a phone from another provider and still keep my same Koodo plan?
  • Updated 6 months ago
I currently have a Tab Large and an excellent plan on a Koodo phone. I need a new phone. Can I bring a phone bought from somewhere else, and still keep my same Koodo plan and phone number? I see there is a "bring your own phone" option at Koodo, but this option does not specify whether it applies to existing customers or not. Thanks!
Photo of marnie
marnie
Posted 6 months ago
Photo of Dinh
Dinh, Mobile Master
  • 41,522 Points 20k badge 2x thumb
Hi marnie,
As long as the phone is compatible with Koodo network, you can put your current SIM in it and it will work
Photo of marnie
marnie
Thank you! Do I have to pay off my Tab balance first?
Photo of marnie
marnie
How do I know if it is compatible with Koodo? For example, if I buy an unlocked phone from Amazon that was on the T-Mobile network, will that work with Koodo? sorry for all the questions. Thank you!
Photo of Robert
Robert, Mobile Master
  • 105,822 Points 100k badge 2x thumb
Check over here : https://willmyphonework.net
Photo of Dinh
Dinh, Mobile Master
  • 39,756 Points 20k badge 2x thumb
If you bought a phone from another carrier, make sure it is unlocked first. Next, you can check its compatibility on various website like https://willmyphonework.net/  or you can ask people in this forum.
Photo of marnie
marnie
Great! That website says the T-Mobile phone will work on 3G and 4G LTE networks, and shows it is thus compatible with Koodo.
Thanks for all of your help Azure!
Photo of BobTheElectrician
BobTheElectrician
  • 65,954 Points 50k badge 2x thumb
Voice of experience: unlocked T-Mobile gear works fine with Koodo, even roaming in the US on yet another network. Check the vendor reputations on Amazon or eBay if you are buying used or refurb. Some are more reliable than others.
Chubbiestech on eBay sells for a little more than some others but the refurb phone I received was indistinguishable from brand new.
