Can I add two $40 plans for international talk and text to my phone for travel in Europe to double the minutes , texts and data?
  • Updated 9 months ago
Photo of Craig Williams
Craig Williams
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Unfortunately not. Only one roaming add on can be added at a time. I believe you can add both the $40 and the $15 add ons at the same time, but that only increases the number of texts you can send.
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
Timo is correct, you can only use one of each roaming add on per billing cycle.
Craig Williams
Ok. Thanks Boys!
Photo of BobTheElectrician
BobTheElectrician
  • 61,736 Points 50k badge 2x thumb
A place to start if you are investigating alternatives:
http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data
Photo of Phil
Phil
  • 60 Points
If I am travelling for more than 30 days, will I be able to add a second, 30-day add-on from Europe by texting ALL40 to 7626?
Yes.
