Can I activate my Koodo sim card and keep my existing number for Koodo and my old plan (Solo mobile) under a new number?
  • Updated 2 years ago
I purchased a used unlocked LG G4 which has an unactivated Koodo SIM card. My current provider is Solo Mobile which no longer activates new customers. I wish to keep the Solo plan under a different number to give to a family member.
From what I understand, my old plan will be cancelled if I go to Koodo with my old number, and my Solo plan will no longer be available. But if I switch the number on my Solo plan first then immediately open a Koodo plan, will Koodo be able to give me the old number? Or can I only keep the old number as long as I hold the rights to it?
My current plan is a pay per use for Solo and I would like a monthly plan on Koodo.
Photo of Steve French
Steve French
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Steve,
You would not be able to move the number. Companies do not release phone numbers right away. They keep it for a period of time to be able to revert back changes just in case. You might just have to get a new number if you want to keep your solo plan the way it is.
