Can calls from blocked numbers be prevented from going to voice mail?
  • Updated 11 months ago
I can block numbers from ringing, but they can still go through to voice mail. Is there a way to prevent this?
iPhone 5s iOS 7.1.1 No data plan 100 minutes unlimited text. no tab. Ottawa
Photo of Dave Ehman
Dave Ehman
Posted 11 months ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,888 Points 50k badge 2x thumb
Hi Dave,I don't believe there is...
Photo of Dennis
Dennis, Mobile Master
  • 200,440 Points 100k badge 2x thumb
There is no way to prevent this.  Any blocked calls or calls, not taken will automatically be sent to voicemail.  There is no way to pick and choose blocked numbers to by pass voicemail.
If this is a big issue, I recommend changing your number on self serve
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 143,306 Points 100k badge 2x thumb
There are call blocking apps that accomplish this by accepting the call and immediately disconnecting it. This does count as a completed call though, and will use your minutes. It would also result in roaming charges if you are out of Canada at the time.
Photo of Dinh
Dinh, Mobile Master
  • 45,294 Points 20k badge 2x thumb
If you are on iOS, you can add "visual voicemail" add-on, all voicemails that are from blocked contacts will not be notified and located in the folder blocked of the visual voicemail.
Not sure if it worth for you, that is a $2 add-on.
