Can a locked public mobile be used for koodo without unlocking it????
If I buy a phone locked to public mobile can I get a plan on Koodo without having to unlock it? Someone said Telus, Koodo and public mobile are all the same so I'm hoping it won't be a problem
Photo of Julie Weston
Julie Weston
Photo of Cameron Jones
Cameron Jones
  • 6,960 Points 5k badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,458 Points 100k badge 2x thumb
No it will need to be unlocked
Photo of Robert
Robert, Mobile Master
  • 103,714 Points 100k badge 2x thumb
Paul, though I've never tried, David Bernard tried it and he says a Koodo phone will work with Public. Therefore, it should work the other way around!
Photo of Dave
Dave
  • 7,814 Points 5k badge 2x thumb
Although sometimes it does, it is safer and more reliable to believe that it does not. We cannot say that your phone WILL work since we are sister companies, but you are right they MAY work.
Photo of Jack Yonge
Jack Yonge
  • 2,350 Points 2k badge 2x thumb
It all has to do with the system code (MNC). Telus and Koodo both use code 220. This is why they work without unlocking. The codes are set when the networks are initially built Fido and Rogers have different MNC codes and this is why they are seen as different networks to the SIM.
That said, Public Mobile is now also using MNC 220. If all holds true, and I have not tested it, they should all (Koodo, Public, Telus) be interchangeable without unlocking.
Photo of BobTheElectrician
BobTheElectrician
  • 61,888 Points 50k badge 2x thumb
Older Public Mobile phones worked on a completely different spectrum.
Previous customers had to upgrade phones, so all bets are off.
My sister in law had to dump her favourite phone from P.M.. I gave her my previous Koodo LG slider, unlocked, and all is good on Public for her.
I wouldn't dream of going in the other direction. The Public Mobile phones are non-data and no-roaming anyway, so even the cheapest Koodo phone is a better deal in the long run.
________________________
If you see an answer you like, please give it a star
Photo of Aneesa Nagji
Aneesa Nagji
  • 60 Points
can i use a telus iphone5 with publi mobile without unlocking it???
Photo of Robert
Yes it should be possible!
