calls to voicemail , count as mobile to mobile?
  • 2
Do incoming calls to voicemail , count as mobile to mobile?,
Just recently topped up my minutes , but haven't made any phone calls or haven't talked cell to cell or landline.
But i just checked and someone left a 1 minute and 22 seconds voicemail .
Just noticed on my booster usage that i have used up 2 minutes.
It appears that it does, just want more confirmation and maybe a breakdown on the booster usage billing.
Photo of Carlos Arevalo
Carlos Arevalo
  • 2
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Incoming calls to voicemail will not use up your minutes. Calling from the cellphone to check your voicemail messages will.
Carlos Arevalo
Thanks Timo ,
Looks like i need to call Kodoo and sort this out with them , because I've been charged 2 minutes of my booster usage.
when you checked your voicemail to find out there was a 1 minute 22 second message, were you calling from a landline or from your cell?
Carlos Arevalo
I have not used my cell to call or check messages yet. i just see on my samsung cell phone under call duration , and under the tab all calls , it shows : Voice call , oo:o1:22 , then i went and logged on my Koodo prepaid account and looked under the booster usage tab , and it shows that i have used up 2 minutes.
Thanks for taking the time to reply Timo!
Photo of quasarito
quasarito
This seems to indicate that you actually made or received a voice call on your phone. Your phone would not report a call duration if someone left you a voicemail. Check your history and see if you made an outgoing call or answered and incoming call (or possibly someone else used your phone).
Carlos Arevalo
@ quasarito, that's where I'm looking in the history of calls , under received calls tab log, it has this as follows:
_____________
Last Call
_____________
Voice call
00:00:00
Video call
00:00:00
_____________
Dialed Calls
_____________
Voice call
00:00:00
Video call
00:00:00
_____________
Received Calls
_____________
Voice call
00:01:22
Video Call
00:00:00
_____________
All Calls
_____________
Voice Call
00:01:22
Video Call
00:00:00
No answered calls, no outgoing calls, no call to voicemail (hence no outgoing calls)
no one used my phone i have been monitoring it , actually heard it going off
didn't pick up the phone , the caller left a voice mail.
Decided to tap on Home button on Android 4.1.2 , on Samsung Galaxy Note 2, takes me to homescreen , then tapped the phone icon, tapped on Logs , then tapped on Menu(left touch button) , then tapped call duration , which displays the information above , the call logs.
by looking at the above info , it tells me the length of the voice memo the caller left.
