calling and texting not working
  • Doesn't Need an Answer
I used my phone for a call went to text ten mins later my texts and calling don't work but I have data working, my phones not suspended , it won't even ring whrn I try and call, tried restarting phone and factory reset no luck put my sim card into another phone and it works!! Help please!!!
Photo of Nicole Kallie Burkholder
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,898 Points 100k badge 2x thumb
Did you accidentally turn on a do not disturb or blocking feature on your phone
Photo of rikkster
rikkster, Mobile Master
Which phone do you have Nicole? Strange, because a factory reset would have wiped any previous settings such as blocking or dnd features and would have returned the device to a factory default state. Again, knowing what device you have would help to troubleshoot the issue further.
Good catch Rikkster I completely missed that she did a factory reset on the device.
Photo of rikkster
Your point still stands Paul, your suggestions may have happened after Nicole performed the factory reset, where she may have inadvertently turned on a do not disturb feature or placed the device in silent mode, after the fact. That's a misprint on my part, I meant to refer to the no calls, no texting and no ringing and that a factory reset in most cases resolves those issues.
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hi Nicole, Was the issue with your phone resolved?
________________________
