Call forward on prepaid
  • Updated 2 years ago
New koodo customer. I have unlocked iphone, base prepaid 15$/month and boosters.
I have configured my phone to forward when I'm busy, out of reach or not answering ... To my home phone line. It worked. I do not have any call forward add-on option and don't see how to add this to prepaid on self serve site. Will I be charged minutes for the forwarded calls ? Do I need to add this on ?
Photo of Eric Mollenthiel
Eric Mollenthiel
Photo of Myke
Myke
As far as I know, call forwarding isn't available for prepaid.
Eric Mollenthiel
Right now on phone I can redirect with
*67* (if busy), 61 (if no answer) and 62 (if unreachable)
Indeed the *21* (forward all) does not work .
Built what I need is what already works (67' 61, and 62) so it,s just a question of knowing how or if I will be charged for the redirected calls.
Photo of Wendy Liew
Wendy Liew
  • 102 Points 100 badge 2x thumb
do you have a prepaid phone and *67, 61, and 62 works?  I want to forward to my US # while i am down there.
Photo of BobTheElectrician
BobTheElectrician
  • 62,198 Points 50k badge 2x thumb
Whatever you do, don't plan on forwarding to a US number thru Koodo, even if it seems to work.
There is at least one horror story of someone on postpaid doing that and racking up a bill close to the four figures.
If you are a regular US visitor and need forwarding across North America, take a cheap plan with CallCentric (VoIP) and have your calls forwarded to both US and Canada for a few cents a minute. I have landline and mobile numbers in 4 different US & Canadian area codes, chosen so that my main contacts never have to pay long distance and I never have to pay for roaming. My bill is almost never over $10 US a month for this service.
Photo of pmjzzz
pmjzzz
  • 60 Points
So is it confirmed that CF works on prepaid?
Do you / can you stack 67, 61 & 62 if you want to CF in all three scenarios?
Photo of Sophia
Sophia, Mobile Master
It's not officially supported, pmjzzz and I can confirm that *21 does NOT work. The others I tried and it only worked as long as the phone was on... when I switched it off call forwarding stopped too. However the last time I tried is more than a year ago, I don't know if things changed in the meantime :)
Eric Mollenthiel
I have prepaid + 67, 61 and 62 all permanently configured and it works even with the phone off.
21 does not work. But you can achieve the same thing with 62 + turning off the phone (or airplaine mode)
Photo of Sophia
Good to know, thanks Eric :)
Photo of Budd
Budd
  • 652 Points 500 badge 2x thumb
It won't be working for long after hour post
Photo of edward
edward
  • 90 Points 75 badge 2x thumb
I use an apple phone with pre-paid and call forwarding has never worked with any of the above numbers.
BobTheElectrician
Call forwarding and roaming (even EXT in Canada) do not work on prepaid.
Photo of edward
edward
They clearly state that they do. Curious..
